adding 3:73 gears
Old 02-13-2006, 11:50 PM
99 Predator's Avatar
Default adding 3:73 gears
will my rear end die a lot faster if i add these gears, and is it bad on the engine since i will always be in higher rpms?
Old 02-14-2006, 12:04 AM
NoGamesLS1's Avatar
auto or m6
Old 02-14-2006, 12:09 AM
its an auto
Old 02-14-2006, 01:23 AM
'99slobird's Avatar
Just put a set in my car, but from past experience you should be fine. What ratio are you running now?
Old 02-14-2006, 07:43 AM
Shamson5.7's Avatar
Your car wont always be in higher RPMs if you shift right. I use 5th (sometimes 6th) around town now instead of 4th. I get the same gas mileage going from 342s to 411s.
Old 02-14-2006, 10:40 PM
right now i have 2:73.
Old 02-15-2006, 12:00 PM
DOUBT IT's Avatar
Mine has lived just fine for a year of hard use now. I have had them in for 16,000 miles. Over 100 1/4 mile passes on DR's, ET Streets, and street tires. I've abused the crap outta these gears, and they've taken it all without a peep.
These are Precision 3.73's btw. I'm about to throw a girdle on and a solid pinion spacer in to go with the TCI 4000 I'm about to install. Combine that with a sticky MT ET Street radial, and we'll see if it adds up to shards of metal in the pumpkin.
Smart money says that the tranny dies first though...
