Strange Dana 60?
Old Feb 16, 2006 | 09:34 PM
My1st Truck's Avatar
Default Strange Dana 60?
anyone know the pros and cons of using a Dana 60?
Old Feb 17, 2006 | 02:06 PM
CW00BlackTA's Avatar
Pros - stronge as hell.
Cons - Big and heavy (overkill), custom installation only (can't buy the parts for a bolt on installation).
Cons - Big and heavy, custom installation only (can't buy the parts for a bolt on installation).
Old Feb 17, 2006 | 02:07 PM
Pros - Strong as hell.
Cons - Heavy as hell, custom installation only (can't buy the parts for a bolt on installation).
Old Feb 17, 2006 | 06:14 PM
flyinZ's Avatar
Yep...I've got one of the prototypes, that were first made ..Installed by Billingsley Racing
Old Feb 17, 2006 | 06:46 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
With adjusters or with out?
Old Feb 17, 2006 | 07:22 PM
flyinZ's Avatar
If your talkin' about the adjusters, that set up the gears..Im 99% sure, yes.
Old Feb 17, 2006 | 11:19 PM
LS1Tech Sponsor
I should have some more information on the Dana 60 with a TA mount with in a week or so. I want to see one for myself and evaluate the ABS options and if there are any issues with the TA bolts like the 12 bolts.
Old Feb 18, 2006 | 10:33 AM
flyinZ's Avatar
The Dana's TA mount, isn't just welded on like the previous 12 bolt, its actually made into the case, as one. I've got a 3 channel,so the options should be the same, as before. Haven't had any issues with the TA bolts, either. So far so good
Old Feb 18, 2006 | 11:34 AM
I talked to strange yesterday, They said they sell a complete bolt in and you send them your backing plates. 2295 Dollars later you have a complete ready to bolt in unit. I just don't want to deal with Moser again.
Old Feb 18, 2006 | 04:01 PM
95 TA - The Beast's Avatar
I have had my order in for almost 2 weeks now... I should have it within a couple more... Mine is also a 3-channel setup, 3.54 gears, aluminum strange cover...
I am just happy that I didn't have to deal with the 2.25" pinion drop the 9" has, as well as retaining ABS... Since I have a 6-speed it was a no brainer...
It will be nice to finally have traction... And not have to worry about breaking the rear as I would have been with a 12-bolt...
Once I get it installed I'll be ordering a Strange driveshaft to go with it... I figure once I break the output shaft of the tranny I'll then rebuild the tranny and put in a viper output shaft and modified housing from D&D to take care of that as well... Should pretty much make the driveline bullet-proof, well at least until someone gets stupid with shifting, then anything can break, but I intend to take it a little easy in that department as I primarily want my car to remain a street car... So I'll give up some ET and granny-shift it...
Old Feb 19, 2006 | 04:47 PM
Formula 1's Avatar
I've got one w/ 373's on order too. 35 spline w/ True Trac...should be nice.
