questoin for those running 9inch with detroit locker
what gear lube are u running???
some are saying to run 75-90 and posi additive
others are saying to use a synethic and not use posi additive
i hope to be putting mine in today, and wanted to konw what gear oil i should go with! thanks
Originally Posted by badpewter-z
85-140 the thicker oil will help keep the chatter of the locker down
should i use posi additve? or are u saying 85-140 synthetic
LS1TECH Sponsor
no its not a posi nor a spool. it actully has two halves that ratecht together. you dont have to add an additive at all. you can use dino or synthetic its really up to you. if its brand new though i wouldnt break it in on synthetic oil id start with regular oil
