GM Gears 3.73s
Thanx
Well with the exception of Richmond. Those gears are noisey no matter what. Trending Topics
Only reason I'm on the second set is the tranny shop either did not torque them to spec OR they didn't use loc-tite. Bolts backed out and cracked the posi housing.
Im not too informed when it comes to a rear gear swap or procedure.
Thanx
Does anyone know which/how much gear oil I should get, and how much of the GM Limited Slip Additive I would need?
