Pinion angle?
Old Mar 26, 2002 | 08:14 AM
Shon Herron's Avatar
Default Pinion angle?
OK, car has Hals on the fronts and sits lower than stock. Has a Jegster TA b/c of the exhaust is so unorthodox, Metco LCAs/Relocation brackets. Measure Pinion Angle, it is 0 to +1, no wonder the car will not hook up!!
Will raising the front up some with the hals make the Pinion Angle different? I am thinking not, but just checking.
NOTE: this is not my car. Dont have the power to need Hals.
Old Mar 26, 2002 | 08:49 AM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: Pinion angle?
Ideally, you want about 1-2 degrees nose down pinion angle in relation to your driveshaft. I hate to tell you this, but pinion angle has very little affect on the hooking capability of these F-bodies. I've tried many different torque arms and many different adjustments to verify this. The proper pinion angle will keep vibration down and parts breakage to a minimum.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 26, 2002 | 08:53 AM
Interesting, what helps the most?
Big tires to hook? What else? if it matters this car is an M6 i am refering to with an LT1 solid roller.
The guy has done very well, he pushed the LT1 HOT cam to 11.9s at 115 but has always had a problem with traction, ET streets is what he runs with 4.1s in a 12 bolt.
Old Mar 26, 2002 | 08:57 AM
Patrick G's Avatar
Tires help the most, then the right clutch is next. You want to be able to launch at 6000 rpms without frying the clutch. McCleod is making some really good ones that are adjustble.
__________________
Old Mar 26, 2002 | 08:59 AM
Eventually i will get all the mods out on the table, Mcleod Twin disc resides in it.
and i dont know what RPM he will be launching from but he has a 2 step to keep it consistant.
Old Mar 26, 2002 | 09:40 AM
Orange Krush's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Patrick G:
<strong> I hate to tell you this, but pinion angle has very little affect on the hooking capability of these F-bodies.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Pat I'm gonna have to call U out on this one! I have over 440 1320 passes on my mostly stock Z, and the one thing I can tell U is, after replacing the factory tourque with the BMR adjustable one I cut consistent 1.9x short times! Those r down from 2.2x! I am running a negative 3* angle and she is a monster as far as traction goes! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> As U can see I run a street tire not a drag radial! So as far as pinion angle goes in my case it had a major effect! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ March 26, 2002, 09:48 AM: Message edited by: Orange Krush ]</small>
Old Mar 26, 2002 | 02:11 PM
Patrick G's Avatar
Orange Krush,
I believe most of your gains came from running a much better torque arm...not from running a deeper pinion angle.
__________________
