12 Bolt girdle?
Old Mar 4, 2006 | 12:09 PM
TieRod's Avatar
Default 12 Bolt girdle?
I need to know what the adjustment procedure is for a 12 bolt girdle. I bought a used one from a friend and he doesn't remember how to set it up
Old Mar 5, 2006 | 09:44 AM
TT402LS1's Avatar
I got the instructions right in front of me. You need to torque the cover to 25lbs. Screw the two load bolts in untill they make contact with the carrier caps. Torque the load bolts to 5lbs. DO NOT OVER TORQUE THE LOAD BOLTS! Tighten the jam nuts on the load bolts. Torque them to 10lbs.
Old Mar 5, 2006 | 09:53 PM
TieRod's Avatar
Thanks,
That what I needed to know.
