People that run 28" X 10.5 slick need advice please.
I'm setting up my new Strange 12 bolt (1&1/8 shortened overall). Did you need to delete your axel bump stops? If I need to delete my bump stops will I regret it later like if I hit a really big bump?
Re: People that run 28" X 10.5 slick need advice please.
My bump stops are still there. When the pressure is low, say around 12 lbs. and I take a corner going around 10 mph, the inside of the tire does rub SLIGHTLY. Not a big deal in my case. Its going to depend on your wheel size/backspacing too.
