Rear ratio -vs- RPM calculator
Old 03-17-2006, 06:09 AM
Red98C5's Avatar
Default Rear ratio -vs- RPM calculator
Does anybody have a calculator for the RPM a specific ratio rear will give?The TCI web site calulator needs to much data that under most conditions you have to rely on manufacturer information, like T/C slippage and such (this info usually is very one sided), also if you need to add the MPH you are going to run, how can you tell what that will be IF you did not yet install it?
Old 03-17-2006, 06:36 AM
blue01ta's Avatar
Is this what your looking for?
http://www.f-body.org/gears/
