How much Gear Whine is normal?
Old Mar 23, 2006 | 09:43 AM
2000Z28M6's Avatar
Default How much Gear Whine is normal?
I recently had a set of GM 3.73s installed and they are working out good, except I have never had gears before on a car. I dont kno what to consider normal whine, or execisive. Usually when the car is cold and under normal conditions shifting at 2k rpm not a sound. Once it warms up, I usually start to hear a lil whine in the OD gears like 5th and 6th, of course this only happens when I'm between 1500 - 2000 rpm. Is that normal? Its not too bad I'm just wondering if thats normal or it will eventually go away, or god forbid get worst.!!!!lol
Old Mar 23, 2006 | 10:01 AM
SSCamaro99_3's Avatar
I have always had a touch of whine in the overdrive gears. Stock and with 4.10's. When my pinion bearing went it was excessively loud.
Old Mar 23, 2006 | 11:16 AM
'99slobird's Avatar
That's exactly how mine is. No noise until I'm in OD, then it gets a little louder when converter locks (I'm running 3.73's).
