best gear ratio?
Old Mar 25, 2006 | 10:18 PM
MY1stSS's Avatar
Default Gears?
which is better on the LS1, 3:73's or 4:10's?
Old Mar 25, 2006 | 10:19 PM
Z28LS1camaroguy's Avatar
what tranny do you have, A4 or M6. if you have an A4 3.42s or 3.73s, and if you have an M6 4.10s.
Old Mar 25, 2006 | 10:26 PM
MY1stSS's Avatar
4.10's won't effect the top end?
Old Mar 25, 2006 | 10:31 PM
TryingT/A's Avatar
4.10s will cut your top speed and your top hp, not significantly. the upside is your car will rev faster, especially with a cam. I have to short shift 1st cause the rpms just fly up there. I suggest getting less resistance wires along with them to avoid misfiring, i had this problem until i replaced them, msd 8.5
Old Mar 26, 2006 | 04:51 AM
Viper's Avatar
Seems the more power you make , you may want 3:73's. For example, I'm at 433rwhp. If I can hook, in the 1/4 I could be at 125mph. With 4:10's I'd have to shift to 5th which is not optimal. I keep thinking if I get a real rear end I'll order 3:73's or 3:90's. Thoughts?
Old Mar 26, 2006 | 05:10 AM
TryingT/A's Avatar
good point viper. but with 4.10's you would get up to 125 quicker(reving to your peak hp quicker. True, 5th is an overdrive gear and not optimal for racing but with 4.10's there is a bigger gap between 5th and sixth. I rarely use sixth, and use 5th as my passing and cruising gear on highways, feels responsive to me
Old Mar 26, 2006 | 09:33 AM
Viper's Avatar
To be honest i drag race once in a blue moon, but wanted to know what's optimal. 4:30's sure would be fun on the street that's for sure!
Old Mar 26, 2006 | 11:20 AM
BrandonDrecksage's Avatar
it depends how much power your putting down, power curve, tranny, rev limit, tire size, drag race, auto x, road race...ect... not to mention your goals and how your gonna driv ethe car(dd or a weekend racer)
Old Mar 26, 2006 | 07:43 PM
Ric's Avatar
Ric
Viper makes a good point if you're gonna be hitting the track and want a good ET. Not only is 5th less than optimal for power transmission, you also lose time shifting that one extra time which could mean the difference between low 12s and mid 11s. Sumpin to think on if you're looking to mod your car.
