ST4000 and 3.73s?
Old Apr 10, 2002 | 10:45 PM
quickWS6's Avatar
Default ST4000 and 3.73s?
Is a Yank ST4000 and 3.73s a good match? What are the **** extensions on this convertor? Average 60' times? How do they do in efficiency? How are they from a roll against a M6? TIA
Yank Super Thruster 4000 Torque Converter, 245mm, hard hitting launch, 4000 stall, 2.7 STR
Old Apr 10, 2002 | 10:52 PM
WILWAXU's Avatar
Default Re: ST4000 and 3.73s?
Better have good tires <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Not sure about the shift <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> extension on that particular converter.. but I'd figure easy 1.6 60fts with traction. This is a realatively new converter haven't seen much on it.. basing my opinion on a friends ST-3700, it should be a kick azz converter.
If you looking for a monster from a roll.. think about a TP-4000 or 4400.
<small>[ April 10, 2002, 10:53 PM: Message edited by: WILWAXU ]</small>
Old Apr 11, 2002 | 08:26 PM
quickWS6's Avatar
Thanks for replying. Okay, how about a 4400 with a high STR and 4.10s? Shouldn't be extremely loose with more gear and about a 3.0 STR, should it? I bet it would hit like crazy, and my rearend and tranny would probably go pretty quickly after that. But it would be fun. Any ideas on that setup?
Old Apr 12, 2002 | 08:45 AM
Ragtop 99's Avatar
The ST 4000 and 3.73s will be an awesome track combo with good tires. It should 60' as well as, if not better than a YTP 4400.
For power from a roll, a YTP 4400 would be a better choice as its efficency and shift extension are better than a ST 4000.
Old Apr 12, 2002 | 11:55 AM
WILWAXU's Avatar
If you have done the gears yet. Get a converter first. You may not want the gears afterward.
The ST-4000 with 3.23's wouldn't be a bad combo.. or even a TP-4000.
If your looking for the all out fastest(quickest) combo IMO... TP-4400 with 3.73's
