No lockup in 3rd gear or higher! HELP :(
Had just finished up a high speed run and was winding out 2nd gear to 107mph or so (2.73's) and when it was supposed to shift into 3rd it banged the rev limiter. Tried manually shifting from 1st to 2nd, (works perfectly) then 3rd, it just revs unless i take it up to about 4K rpms and it will semi-lock and accellerate normally that is until 107 mph when i need third.
Of course in normal city driving it goes from first to second normally then 3rd it just unlocks and doesnt stop revving. I had to limp home in 2nd gear so i wouldnt burn the tranny up due to a unlocked converter for 50 miles or so. <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" /> However maybe I have already burnt something up. Tranny only has 20K miles on it and i have the Yank St3500 in with a correctly installed transgo shift kit and a B&M tranny cooler. Converter/kit/cooler has been on for the last 10K miles or so.
This happened once before after i was racing at the track and was stalling it up high. Turned out to be PCM related cuz after i reset the computer everything was normal. This however just happenend with no notice with nothing but some WOT runs. Fluid level is fine and it is still red.
Something tells me im gonna have to drop the tranny put the stock verter in and go to the dealer, what PIA <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Sean
So i guess that is pretty much describing no 3rd gear huh? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Sean
