3 channel? 4 channel???
Old Apr 18, 2006 | 05:16 PM
RA4926's Avatar
Default 3 channel? 4 channel???
i did a search and didnt find any real information and it probably been posted a millions times but....how do i know if its a 3 channel or 4 channel. i think it has to do with abs and tcs. i only have abs and there is a wire going to what i guess u could call a plug on top of the center unit(pumpkin). im ordering a moser 12 bolt tomorow morning and i think i need to know this info. thanks in advance.
Old Apr 18, 2006 | 05:23 PM
2000Z28M6's Avatar
If you have traction control you have 4 channel. If not its a 3 channel.
The difference is in the gear for the traction control, it is located behind the wheel studs.
The wire you refer to is your rear wheel speed sensor, if you had 2 then you would know its a 4 channel. So to answer your question, by what you have told me so far it looks like you have a 3 channel setup.
Old Apr 18, 2006 | 05:34 PM
2001NBMZ28's Avatar
Sensor plug in on top of the pumpkin/no ASR - 3 channel ABS.
Old Apr 19, 2006 | 12:38 AM
RA4926's Avatar
thanks guys
Old Apr 29, 2006 | 06:49 PM
quiksilver9531's Avatar
is it possible to have a 4 channel abs without having traction control, because I have 2000 ws6 without traction control and I have a a sensor going to each wheel??
Old May 12, 2006 | 04:30 PM
alamantia's Avatar
Yeah me too, my rear has connectors on each hub, no connector atop the pumpkin but it has no ASR so would that ba a 3 or 4 channel, anyone know?
