Did I Break It??
Last night at the track, i was having some issues with the rear end...During burnouts the car would slide the *** around for a while, which it never does. Found out later driver's side tire wasnt spinning until halfway thru the burnout. when i rolled out of the burnout, the car felt like it jerked and made a nasty clunking sound, just once....launched alright, 60' a little off, but nothing major, but the car was "assy" as hell the whole way down the track, and i could hear what sounded like rocks hitting the fenderwells. someone also told i smoked the tires, which i never do, so could have been something else smoking.
after going down the return road, i noticed the back of the car trying walk on me, like it was fishtailing at 10mph..and while turning is, very slighty, but still kind of bouncy....i was thinking broke axle, but...
pulled the cover off today, oil is blue-ish gray in color, not very much metal shavings, no c-clip laying in the bottom of the housing like the last time i went thru this.
the only thing i noticed is when rotating a tire, it will kind of jerk and make a very faint popping noise every once in a while, it is very inconsitant, but happens more often at higher turning speed. also while turning left to exit the track and hit return road, car would make squealing noises from the rear, high pitched and very loud, almost sounds like brake squeal, but i can be under light accel and it still does it.
any help would be appreciated before i take the car to the shop. I would like to try a few things or maybe get advice of something to look for. all teeth look ok, groove marks in a few spots, nothing major.....i am just at a loss.
Thanks in advance!
here are some pics, at that will help at all!
http://community.webshots.com/album/549764885gYnvCE
if so, you cant tell in the pics, but they are somewhat squared off at the tip, but however all 3 still turn when turning the wheels....are they supposed to be squared off or come to a point at the tip??
