Will 288 Slave be ok?
Old Apr 21, 2002 | 01:54 PM
ExtremeZ28's Avatar
Default Will 288 Slave be ok?
I have stock 98 everything when it comes to hydraulics and clutch.....im buying a clutch soon most likely the Ram 402/6130 combo with resurfaced flywheel and a Mcleod Adjustable Master.....now my question is will the 288 slave work for this combo or should i get a 01/02 model??
Thanks
Jay
Old Apr 21, 2002 | 02:03 PM
ExtremeZ28's Avatar
Default Re: Will 288 Slave be ok?
also will the ram adjustable master cylinder work just as well?? i see its a little cheaper then the mcleod but i was just curious if anyone has had any experience with it??
Old Apr 21, 2002 | 02:40 PM
Jason99T/A's Avatar
I can shift faster than you.
I'm using the 288 slave in my car now with great luck. The only major difference between the 228 and the 145 slave is the shim.
I would use the Mcleod adj. m/c in any LS1/LS6 clutch application.
Old Apr 21, 2002 | 03:14 PM
ExtremeZ28's Avatar
thanks man i actually just got a good deal on a new one for 50 bucks so im just making sure its good <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
