what is the best posi repacement for a 10 bolt?
You can get a Detroit locker from Summit for 519.95. you have to look it up on the website, its not in the catalog. Im putting one in my 10 bolt this weekend. Im sick of peg leg burnouts and shitty traction with my Torsen. A buddie of mine put a Locker in his and loves it. That was enough for me.
Originally Posted by The LT1 That Could
sooo, for straight line performance alone....very rarely driven on the street, and never goes corner carving, would the Auburn/Eaton be a better choice, or the Zexel Torsen??
Eaton Limited Slip in 10 bolt problems
i installed an eaton limited slip in my 10 bolt a few months ago. I went to the track launched at low rpms with an m6 and didn't see any lower 60' times because i was on street tires. When i put on my mt et street radials i burned out with only one wheel peel, cut a 1.970 60' and lowered my et by 3 tenths. I think that i smoked the clutches and am going to rebuild with stronger springs. Other than this, i think that the eaton is a huge upgrade over the stock zt...
i had my eaton installed at a local performance shop. They used 3 quarts of synthetic royal purple with no limited slip additive. Could this possibly be my problem...
Actually, your local shop should cover ALL of this since (new unit, removal, installation, etc.) they should KNOW better than to use RP (or ANY synthetic) in an Eaton CF posi!! Just make sure that they use a good MINERAL, NON-SYNTHETIC based gear oil when it is done.
