driveshaft safety loop bolt size
If you're referring to putting a driveshaft loop in place of the OEM tunnel brace,the OEM tunnel brace would have been attached with 8mm x 30mm(length) bolts.The thicker bracketry of a well constructed driveshaft loop would require longer bolts.I use 8mm x 40mm for mine to accomodate the SLP driveshaft loop and bolt-in subframe connectors.
