Weight Difference???
Old May 17, 2006 | 09:32 PM
1BAD98LS1's Avatar
Default Weight Difference???
I just bought a brand new 9" from Moser and im having reloc. brackets welded to it. Its got the alum center section, alum pinion support with a detriot locker and 31 spline axles. How much more will this weigh than my 3:73 ten bolt w/ TA cover, etc?? Going for under 3K car weight...
Old May 17, 2006 | 10:08 PM
Super Sport Beast's Avatar
I think, when I was getting my Moser 9" I was told its about 50lb+ havier than stock 10bolt
(but I'm not 100% sure though)
Old May 17, 2006 | 10:22 PM
1BAD98LS1's Avatar
Yours have alum center section??
Old May 19, 2006 | 07:22 PM
1BAD98LS1's Avatar
Anyone have any idea
Old May 19, 2006 | 09:47 PM
93formto98T/A's Avatar
I just got a moser 9"/N case/true trac and by the UPS ship info everything weighed 220 WITH Packing. I didn't get to weight the 10 bolt but have heard they average around 190. Looks like about +30 BUT I countered that with a cutom 3.5" alum DS which lost me 10-13 lbs over the stock steel DS. So I came out 10-15lbs heavier but TONS stronger. Just got her all broke in and she is as quiet as stock but feels much tourqier even though I went with a taller gear.
Old May 19, 2006 | 10:39 PM
burnzilla's Avatar
About 20 lbs heavier, but well worth it.
Old May 20, 2006 | 08:05 AM
1BAD98LS1's Avatar
Thats interesting, i should be a few lbs lighter with mine since i ordered the alum. options. by looking at your sig you need the nodular and the big azz ds
Old May 20, 2006 | 09:18 PM
Yeah, I wanted to do it one and do it right. I'm planning on retuning this fall for 900rwhp and I'll put some strip passes on her so I don't want to have to worry about anything breaking! BTW alum case is ~15lbs less than N case.
Old May 20, 2006 | 09:25 PM
badpewter-z's Avatar
LS1TECH Sponsor
moser 9" alum center, 35 spline gun drilled, locker, it was pretty damn close if not a shade lighter than the 10 bolt that came out actullynever actully weighed either for exacts though.
