Can I get less vibration with a Poly Tranny mount? I think I can!
I know that I poly tranny mount will allow you to feel more of the tranny shifts, bumps, rear end vibes, and things like that. My car seems to have a vibration when under heavy accerlration and at high speeds (90+). Whats going on is my pinion angle is changing when the tranny moves or torques. Energy Suspension does say that the poly mount does help maintain proper driveshaft angles. I think I might give it a shot.
I have played with my pinion angle but that does not stop the vibration, but it can make it worse. I have a custom crossmember that makes it hard for me to adjust the pinion angle. Instead of puting the finder on the driveshaft I have to put it on the output shaft or yoke coming out of the tranny. Mike (Yank) told me what to do but I did not write anything down and forgot. I have a 4L70.
Thanks
Brian
Thanks
Brian
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
you should be setting your pinion angle at the rear of the driveshaft and on the rearend yoke, not at the tranny. maybe thats why you have vibrations?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by chevyguy3:
<strong>you should be setting your pinion angle at the rear of the driveshaft and on the rearend yoke, not at the tranny. maybe thats why you have vibrations?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have been setting it using the rear of the driveshaft but Mike at Yank told me that it is different for the 4L70 with its type of crossmember. I just forgot what he said. I'll e-mail him.
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
1 Post
poly mount = ****.
You will NEVER get that vibration out. Stick a stock mount in and it will go away.
Tim
Tim
I really can't see a poly mount REDUCING any kind of vibration. I put one in after breaking my stock one and then took it back out 2 weeks later.
It seems to me that the stock tranny mount cannot really permit that much movement - expecially from torque. I believe that more movement can be traced to the motor mounts.
Your vibration may or may not be related to your pinion angle but putting a poly mount in will give you vibrations you never knew you had <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> !!
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Steve
