Odd TC lock up issue...
Old May 15, 2002 | 02:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Odd TC lock up issue...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Reboot:
<strong>change the misfire temp table and your problem will be fixed. I used to have this problem after my cam install and found that all worked well until i got caught at a couple of lights then it wouldn't lock anymore. If I turned the car off and on I could cruise the freeway for hours without issue.
I had John at www.speartech.com fix my issues for me.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the info. I was hoping it was just going to be the temp table. I'm planning to get edit soon so I'll give that a try first. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 16, 2002 | 12:46 AM
RPM WS6's Avatar
Default Odd TC lock up issue...
Since the cam install, my TC lock-up is intermittent. Truth be told, I like it better unlocked at speeds below 50mph, but I would like it to lock up on the expressway. It seems that it will only lock when it feels like it. I’m sure it has to do with misfires or something, but what I can’t understand is why it’s intermittent? Why doesn’t it just stay unlocked? What makes it suddenly start locking up sometimes? Sometimes it will work fine for miles, then suddenly stop <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
My PCM has been tuned, and I understand from some that if I use LS1 edit to change the misfire temp readings to like 139/140 that it will start locking up. At this time I don’t have Edit, and I’m not entirely sure that this is the issue since it’s intermittent. Oh, and my Ltrims are fine so I don’t think that’s it either, and I have a totally stock MAF. It also seems that the tranny tends to lock better when it’s above 180 (I have a deep truck pan and B&M cooler plus cooler fan settings that keep the tranny around the 170 range most of the time).
So I guess what I’m asking is, are other cammed cars just having an intermittent issue, or is it all the time? I have a B1, BTW, and a SY3500 ‘verter that locked up just fine prior to the cam.
Oh, one other thing...is it hurting the 'verter in any way to not be locking? Just wondering...
<small>[ May 15, 2002, 12:48 PM: Message edited by: RPM WS6 ]</small>
Old May 16, 2002 | 12:55 AM
Reboot's Avatar
