Clunk Sound
Old May 18, 2002 | 12:07 AM
Skipp's Avatar
Default Clunk Sound
In my previous post, I stated I heard a strange noise and felt a jerk when I was making a turn at the light. Tonight the same thing happened again. This time I heard "clunk clunk". Anyone have an idea what is causing this? It's obviously something in the rear end. I was able to drive home, but felt a serious loss in power. This sucks! All input appreciated.
Old May 18, 2002 | 07:29 AM
Ragtop 99's Avatar
Default Re: Clunk Sound
I'd put the car on jackstands and pull the pumpkin cover and look for signs of obvious damage.
Old May 18, 2002 | 08:35 AM
2000 Camaro SS's Avatar
Skipp
What about ... Dropped a C-Clip (U did just have new gears installed) When U turn the axle moves in and out. Friend U need to look inside of the rear end I would hate to read about U being killed from flipping or slinging an axle.
Post another post about this in the Texas section someone might be close enough to come over to help U look into this. Most of the Texas people sound like a great bunch and very helpfull!
<small>[ May 18, 2002, 08:36 AM: Message edited by: 2000 Camaro SS ]</small>
Old May 18, 2002 | 07:22 PM
NastySSoo's Avatar
Just had new gears installed? Are you sure limited slip additive was put in ? Just a thought.
Paul
Old May 18, 2002 | 08:25 PM
Skipp's Avatar
The gears were installed two months ago, then installed again a month ago. They were not set up correctly the first time, and they weren't set up correctly the second time either. The shop that installed them, also put a non-synthetic 85w140 fluid in, and two tubes of limited slip instead of one. I drained the fluid after the second install and put in 75W90 synthetic with limited slip additive. I don't know what the hell the shop did to it after the second install, but it's far worse then it was after the first time. I maybe walking here soon. Don't have the money to buy a new set of gears and have an install done right this minute.
<img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 18, 2002 | 10:14 PM
Skipp's Avatar
As far as opening the cover and looking at the differential goes, my first question is, will I have to take off the rear sway bar to open the cover? It is extremely close to the cover. Once I get it open, what's the first thing I should check? My apologies for all the questions, i'm trying to learn more about rearends and want to find out what is wrong with this thing.
Old May 19, 2002 | 12:15 AM
Skipp's Avatar
Thanks for the input. I'll get this looked at asap. As far as driving my car, I'm trying not to anymore than I need to. I hate to have to park it, but may have to before too long. Broke <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> . No pun intended.
