Moser 12 bolt with 1350 yoke. Driveshaft length?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by onfire:
<strong>1350 standard or 1350 Billet?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Standard. I really don't think the Billet is necessarry with my power levels.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
one of them is an inch longer than stock; so the ds would be an inch shorter. I dont know which though. I have the 1350 yoke on order w. a new ds, but I dont know which one they measured to make the new shaft.
Coal Mining Director
I've only used the billet yoke and it is 1 inch too long for the stock shaft. I would try the factory shaft in a 1350 standard yoke and see if you have around one inch of slip clearance at the transmission. Others have posted that the stock length shaft works with the standard 1350. If I had it to do over I would have ordered the standard 1350 yoke also.
Thanks guys. I ordered a Denny's 3.5" HD aluminum unit today. They said they knew what size I'd need.
if your plan is to get a denny's shaft, and you have a 6 speed, tell denny to pull my specs(David Childress), i cant remember what i measured it to be. but i did run the stock ds for a while, it was tight, but it "worked"
i have a moser 12 bolt with non billet 1350 yoke.
