4.10 or 456?
i;d really like to see what a stck ls1 run with a 4.10 and a 456 at the track. if anyone know plz tell me.
I wouldn't go 4.56s if your planning on running stock height tires, especially since your spraying.
At 6800 the top speed in 4th with 4.10s will be 127 with the stock height tires. It's 115 now at 6200.
Shifting to 5th at the track sucks ***, I tried it on the spray and I hated it, can't wait for the heads/cam so I can rev this thing on out and stay in 4th.
Are you guys running 12 bolts or 9 inch rears? A 7.5 with that much gear and tires will go through gear sets like a fat kid through skittles
-Will
I may be trying for a solid roller 402 or 408. If i do then ill definately get the 4.88's, atleast i think i will.
Oh and i almost forgot some important information. I am also looking to do a wheel change at the same time i do my rear-end. I am going to switch from the stock 17's to a set of 15's and change my Nitto DR's to some ET streets around 28*13.5*15's.
www.f-body.org/gears
Play around with that for a while. A good spray setup would be 4.10s + 28"s if your going to be deep in the 130mph zone.
Then i want to do a built 402 or bigger with a solid roller cam. Revving to about 7500rpms and change the gears to some 4.88's. Same size wheel, but i want to see if i can get those damned 31" tires in there. I dont mind cutting out the plastic from the fender if i need to. I really dont even care if you can see the tires from the inside of the car. I will ofcourse have to fab some sheetmetal to cover them up, because of rocks and stuff.
So where does this sound like it'll put me. I am shooting for running around a 12.0-12.2 with just bolt-ons and gears. Does this sound do able or not?
