4.10's on a Torsion???
I hear you need to get something different to install the 4.10's. I've always had 4.10's I just am installing a Torsion. What do I need a where can I get it?
Re: 4.10's on a Torsion???
There's nothing different, except you have to grind down the block-shaped cross-shaft (in the center of the differential holding the axles in place). The 4.10 ring gear is much thicker and will block the cross shaft from going back in, if it is not ground down enough.
hmmmmmmm, how far down? I don't want to create any slack in the axles and basiclly rely on the brakes to hold them in place, do you just grind down a corner?
