What size gear do I have?
Should be 3.23 (GU5) on the drivers side door. If you suspect they may have been changed look at a calculator like www.f-body.org/gears/ My door says 2.73 (GU2) but have 3.42's in mine.
That will probably depend on the model. Like the WS6, Firehawk, regulay Firebird, regular Trans Am, Camaro SS, Camaro Z28 or base model. Also the difference between manual & auto will make a difference.
Originally Posted by Gauge
Which A4s came with the 2.73s and which came with the 3.23s?
But as far as A4's w/2.73's, that's the "standard" ratio for A4's, with a steel driveshaft, but any Z28 / Trans-Am could be ordered with the 3.23's as an option, so it's hard to know for sure how many had what. Chances are the majority of "base" V8's got the 2.73's.
