Vibration in the drivetrain
I recently installed a new Dana S60 w/ 4.10s, Spohn tranny mounted adjustable T/A, and steel driveshaft in my car. Since the install the car has been vibrating quite a bit. It tends to vibrate a small amount around 40-45mph, but it tends to go away after that... until 60mph where it starts up again. From that point up it gets worse. At 120mph the car feels like it's about to fall apart.
The first thing I tried doing was taking the driveshaft back to the place that shortened it for me. They said the weights needed to be moved a slight amount, and they were. This made a very, very small difference. The issue is still 90% there still.
I have also tried resetting the torque arm a couple times. I back the car onto some ramps (rear only), slap an angle finder on the bottom of the bracket going over the differential, and then place it on the driveshaft. I then subtract the differential angle from the driveshaft angle. I have set it at -2, -1.5, -1, 0, and most recently -3. I have had no luck with this.
I soon plan to change the motor mounts (I very seriously doubt this could have any effect, but they need it anyway). Then I will have the new torque arm removed and cut so that I can use the inner bolt holes. I doubt that will make any difference. While it is off I will throw the stocker back on there to see if it makes any difference.
I anticipate that these steps will show that the torque arm had no effect and that the motor mounts will not either. What am I to do at this point? Go back to the driveshaft place? Consider possible problems with the Dana? If there are possible problems with the Dana, what in the world could they be that wouldn't cause other horrible noises and such?
Any other ideas before I follow Walking-dead's advice?
