Gear Size?
Old Jul 31, 2006 | 11:31 AM
knight rider WS6's Avatar
Default Gear Size?
Just wondering what gear size I have on my 2001 A4 ws6.
Old Jul 31, 2006 | 11:53 AM
2001NBMZ28's Avatar
A4's came with either 2.73 (GU2) or 3.23 (GU5), the codes are on the driver side door - believe the SS and WS6 got the 3.23's.
Old Aug 2, 2006 | 04:26 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Yup, and the stick cars came with 3.42's
Old Aug 2, 2006 | 12:58 PM
So since mine is A4, could I throw in a 3.42? Lookin' for a boost here.
Old Aug 2, 2006 | 02:44 PM
2001NBMZ28's Avatar
If you have 3.23's I wouldn't bother, not much of a difference - considered a torque converter?
Old Aug 2, 2006 | 11:49 PM
Don't wanna sound dumb, but how much is a torque converter gonna help, and how do they work?
Old Aug 2, 2006 | 11:50 PM
Studytime's Avatar
It'll help way more than gears. How do they work? Well, you know that sweet spot at 4,000 RPM when your car pulls really hard? It'll make your car do that instantly without waiting every time you get down on the gas.
Ben T.
Old Aug 3, 2006 | 12:14 AM
Sounds good brother. I'm lookin' for that extra punch. The only kick I get is when it downshifts under 30mph. Above that it don't do jack.
Old Aug 3, 2006 | 01:14 AM
brightgreenZ's Avatar
Put in a 3.73 gear and don't look back!!
Old Aug 3, 2006 | 10:00 AM
That's what alot of people have been telling me. That maybe the bosst I need cruising above 30mph.
Old Aug 3, 2006 | 10:07 AM
Studytime's Avatar
A CONVERTER will make a bigger difference than gears will make. When ever you change out your gears for a higher numerical ratio they will only get weaker. You factory gears are, generally speaking, the most durable 10-bolt gears.
A swap from 3.23:1 gears to 3.73:1 gears will provide an additional 15.5% more torque to your rear wheels from increased torque multiplication. A higher stall torque ratio in a premium torque converter could add an additional 35% more torque at the rear wheels or more.
Search (here and yahoo/google) "stall torque ratio," a.k.a. "STR" and you'll see the light. Percision industries and Yank both make great converters, and I'm pretty sure both offer information on STR on their websites.
Ben T.
Old Aug 3, 2006 | 10:22 AM
Thanks for schoolin' me here. I need answers like this. Just need to be pointed in the right direction. I'm just tired of not having the power I think the car should have.
Old Aug 3, 2006 | 10:32 AM
Studytime's Avatar
Do you have any check-engine lights on? It should feel stronger towards the top of each gear instead of the bottom ("below 30 mph"). You car might just need a tune up.
Ben T.
Old Aug 3, 2006 | 10:55 AM
No ses lights. The car has 24,000 miles on it but it is 5 years old. So a tune up might help. I'm talkin delco plugs and wires. That might help give me the boost.
Other than that the jet reprogrammer I've been using to up the rev limiter and shift points has helped a little. Hey, I'm sick of only getting power bellow 25mph. And even then might neck isn't that sore.
Old Aug 3, 2006 | 10:57 AM
Studytime's Avatar
Or Copper NGK TR55s gapped at .055" and a set of Taylor wires?
Search these items while you're at it.
Ben T.
Old Aug 3, 2006 | 11:03 AM
Do you really think those brands are gonna make a difference than delco's?
Old Aug 3, 2006 | 11:22 AM
Studytime's Avatar
Preference mostly. I do know that a Cu plug will provide a hotter spark than an Iridium/Platinum plug, they just don't last as long.
The Taylor wires are going to be built better and could have less resistance than OEM wires.
Ben T.
Old Aug 3, 2006 | 04:14 PM
I' not worried about the longer lasting ones. But I did hear the delcos run cooler.
