Rear problem (pic)
Old Aug 3, 2006 | 07:56 AM
Christian8A's Avatar
Default Rear problem (pic)
There was a leak on that part of the rear end that I saw about 1 month ago, dont know since when actually started but how do I fix that? and how important is it?
thanx
Old Aug 3, 2006 | 08:04 AM
keliente's Avatar
#1 https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
Old Aug 3, 2006 | 12:21 PM
Good info thanx , hey is there any detailed step by step how to repair it or at least how to put the additive?
Old Aug 3, 2006 | 01:25 PM
keliente's Avatar
If you are not familiar with rear ends it is something best left to a shop, since you will be dealing with critical measurements. If you look in the FAQ there is a link to an entire gear installation that gives you an idea of how it all comes apart, although for a pinion seal you would only be taking apart the front.
