lt1 273 to ls1 342 help
Old Aug 3, 2006 | 11:57 PM
cyamaha2007's Avatar
Default lt1 273 to ls1 342 help
Hi i have a 1995 ta with an a4 i want to put the gears from a ls1 m6 into my car. The ls1 rear end was free and i would like to not spend any money at all doing this. The rear end from the ls1 has a bad pinion seal i just would like to get some feed back if this is possible. Thanks alot
Old Aug 4, 2006 | 07:02 AM
keliente's Avatar
Yes it is possible, I think the only thing you need to do is change backing plates, the LS1's won't work. To fix the pinion seal see the FAQ, you might have to take it somewhere if you are not familiar with rear ends.
Old Aug 4, 2006 | 09:35 PM
thanks i wanted to know if i could put the gears out of the ls1 in my rear end sorry for not being clear thanks for the help
