Slave disconnect trouble
Old Jun 8, 2002 | 06:07 PM
Jax White TA's Avatar
Default Slave disconnect trouble
My master cylinder line wont connect back in to the slave cylinder. I have done this before and it just pushes in and clips into place. I have pushed and pushed and it wont go in. Is there something I overlooked?
Old Jun 8, 2002 | 07:41 PM
NB99Z's Avatar
Default Re: Slave disconnect trouble
Open the bleeder valve on the slave and it should push right in.
Old Jun 10, 2002 | 01:01 PM
This worked perfectly. I never knew the pressure build-up from bolting down the tranny (compressing the slave) would cause this. I was getting scared there for a minute that I'd need to pull the tranny back out to check the slave.
Thanks!
