strogest rear end out there!
Old Aug 7, 2006 | 08:44 PM
blk97z28's Avatar
Default strogest rear end out there!
i have a 97 z28 a4 with 73k on it! i have cut open air box and mangaflow cat back i want the strogest rear end avialbe i don't care what the cost is!
Old Aug 7, 2006 | 08:58 PM
waiting2bl33d's Avatar
i think the strongest is the 9 inch but most a4 guys will go w/ the 12 bolt
Old Aug 8, 2006 | 04:56 AM
EPP's Avatar
EPP
Moser 9 Inch with Truetrac for F Body, your choice of gear ratio
31 Spline Axles
$2,400.00 Shipped by UPS
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Shipped by UPS
Call us at 260 244-4808. Rear ends are ready to ship two days after order is received. Thanks! Bob
Old Aug 8, 2006 | 05:46 AM
Carter Hays's Avatar
There is also the strange S60 if you want to keep your 3/channel. A Ford 9 is the de facto standard for drag racing if that is your thing.
BTW Those are good deals Exotic Performance Plus posted.
Old Aug 8, 2006 | 02:00 PM
Firechikn's Avatar
You guys don't get it, he said the strongest. You need 9", 40 spline (gun drilled for weight reduction ), wide 5 bolt pattern, and a spool. That should hold you. I've got 35 spline axles in mine, and them some big mfers, 40 s would be huge by large. oh yeah a fabricated housing, with a back brace, not a tube housing.
Old Aug 8, 2006 | 02:33 PM
slow trap's Avatar
that rear would indeed be a great rear for a strip only car but very overkill for a street/strip car.unless he is in the 1000 + hp range a regular ol' 9 " will be more than enough but you are correct,your reccomended rear would be very strong.
Old Aug 8, 2006 | 02:54 PM
BURN'EM's Avatar
My 9 is a tooth pick in comparison to this thing.
Old Aug 8, 2006 | 03:08 PM
Ace$nyper's Avatar
Try one of these, just bolts up.
Old Aug 8, 2006 | 03:11 PM
Firechikn's Avatar
Yeah, way over kill, but he did say "strongest". On a side note, you'll need to add about 100 hp to compensate for the power loss. lol. I've got 35 spline axles in mine just for the added insurance for those hard launches on a m6, if I ever break those I'll be proud of myself.
Old Aug 8, 2006 | 11:28 PM
blk97z28's Avatar
Default sry i mean something else
i want a good rear end that i can have bout 300ewhp-600rwhp but i want 373's gear!
Old Aug 13, 2006 | 06:20 PM
spootnik's Avatar
Dana 60, hands down.
Old Aug 13, 2006 | 07:17 PM
chicane's Avatar
Modular 11"
http://www.markwilliams.com/Catalog/pg43.pdf
Old Aug 13, 2006 | 07:32 PM
SSilverSSurfer's Avatar
18 wheeler rear end hands down
Old Aug 13, 2006 | 07:39 PM
juicedls1's Avatar
I have a mosar 9" 33-spline with a spool no problems at all 1.52 60ft with a dry 100 shot. $2100 at texas speed performance.
Old Aug 13, 2006 | 07:46 PM
Black FormulaLs1's Avatar
i am telling you to look at the Strange Engineering 12 bolt..makes the moseur look like tooth picks...like $2300
Old Aug 13, 2006 | 08:13 PM
227Hawk's Avatar
If you can tolerate the wieght the Dana 60 is a brute.
Hawk
Old Aug 13, 2006 | 09:03 PM
bygblok's Avatar
I'm pretty fond of my 9" moser peice...especially since it hasn't broken(yet). The disc brakes are great too seeings how my old 3rd gen camaro came with drums. I wasn't too fond of the stinkin' brake lines I had to deal with since GM uses those stupid nipples on the end of the factory lines. Oh well, thats why they make tubing cutters and flare tools!! Oops, yep, still like my 9" even better than the 12 bolt.
