Will I notice a difference going from 2.73-3.23
Old Aug 8, 2006 | 12:18 PM
mccollum_007's Avatar
Default Will I notice a difference going from 2.73-3.23
Just wondering cause my carrier bearings are getting pretty noisy and I've got a low mileage 3.23 rear out of an '01 z28 that I'm thinking about buying. I'm not buying it for performance reasons but still if it does give me any gains thats just another perk...
Old Aug 8, 2006 | 12:38 PM
2001NBMZ28's Avatar
I went from 2.73 to a 3.42 rear out of an M6 car, I noticed the difference, but also did a TC soon after. Make sure the donor rear is the same channel ABS as yours.
Old Aug 8, 2006 | 12:49 PM
Mine has TCS and ABS and so does his so I'm assuming they're both 4channels, correct?
Old Aug 8, 2006 | 01:21 PM
2001NBMZ28's Avatar
Yep, 4 channel.
Old Aug 8, 2006 | 04:10 PM
todddchi's Avatar
The around town seat of the pants difference is quite large, while 1/4 mile times are only a couple tenths. Unless your car is a true highway queen then you'll be happy.
3.23's are very well matched to auto cars, they really never should have put 2.73's in. 2.73's are great highway gears but make the cars real turds around town and off the line.
You will get better track times out of a converter, but if you have a cheap route or need to tear in there anyways, 3.23's are worth it.
Old Aug 8, 2006 | 04:24 PM
So you think I will shave a tenth or two off my time at the track while doing it?? We only have 1000ft. tracks around here but I figure all the benefit of gears has been had by then anyways...
