Rearend noise
mine started to whine and I pulled the rear end to find the pinion gear had a couple of teeth cracked which still does not make sense why. The teeth that has cracks, it was at the toe of the gear and not in the area that makes contact with the the ring gear. If I did not take it apart and fix it, it would have come a part and really screwed up my rear end.
Bill
If its the gears, will a new set of gears fix the problem? My car's got 84k on it ... and it just started whining out of the blue, is this typical?
After looking at my pinion gear, I found more cracks. It looks like four teeth were ready to come off - there are fine cracks at the other end of the gear. Under pressure the gears were making a real funny sound - like the gears were separating from it. Don't wait, pull the gears now and inspect them - like I say the ring does not have any damage.
thanks
Bill
