Quick gear swap question.
Old Aug 9, 2006 | 04:41 PM
666 speed's Avatar
math > me
Default Quick gear swap question.
I have a quick question about going from 3.08's to 3.42's. The carrier is obviously different so I have the gear spacer. Part # MOT75S "Motive Ring Gear Spacer - required when going from 2.73." For the install kit, I was looking at yearone.com and found part # MG75IK "Motive Gear ring and pinion installation kit includes pinion nut, pinion seal, crush sleeve, pinion shims, carrier shims, ring gear bolts, thread locker, marking compound, brush, and gasket." My question is will that install kit work with the gear spacer? Or do I need something specific, or will it matter? Sorry if that sounds stupid, thanks!
Old Aug 9, 2006 | 07:51 PM
keliente's Avatar
3.08s? What kind of car do you have?
Those bearing kits are going to be the same no matter what carrier/spacers you have, don't worry about that.
Old Aug 9, 2006 | 08:23 PM
666 speed's Avatar
math > me
It's for my cousins '99 v6. Thank you, that's exactly what I needed to know!
