9" vs 12 Bolt......
Old Jun 13, 2002 | 09:42 AM
Ws6Luvr's Avatar
Default 9" vs 12 Bolt......
First off who has the 9"? do you have any problems with it, fittment issues, etc? How much heavier is it? how much more power does it rob?
How strong is the 12 bolt? Will it withstand rev limiter launces every weekend, and not worry about it? Also, how fast can you go and not worry about it breaking? 9's? 8's?
Thanks
Nitin
Old Jun 13, 2002 | 10:06 AM
Fireball's Avatar
Default Re: 9" vs 12 Bolt......
I've seen a few 12 bolts have issues with the hard M6 launches
I run the 9" with a locker and fitment was good. its a tad on the heavy side and I get some gear noise (its hard to keep a 4.71 pinion quiet <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) Haven't broke it yet <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
(moser 9" with strange nodular iron center section)
<small>[ June 13, 2002, 10:06 AM: Message edited by: Fireball ]</small>
Old Jun 13, 2002 | 11:10 AM
Ws6Luvr's Avatar
How much heavier is it? Is it easy to change out centersections? With the locker does it click a lot, or is it a soft locker?
Don't most places that sell a 12 bolt have warranties or anything?
haha, i was actually needing to talk to you also, ahah, awesome.
I wanted to talk to you about your gearing. What gear are you finishing the quarter in? what tire are you running (how tall)? What 60's are you cutting? do you feel it is overkill? how fast does every gear wrap out? Did you see a significant difference over, let's say a 4.10 gear ratio?
thanks a ton man
Nitin
Old Jun 13, 2002 | 11:30 AM
Fireball's Avatar
about 38 lbs as listed on BMR's site
well thats debatable...you have to pull the torque arm and the three big *** bolts that hold the torque arm mount to the rear...after that its pretty easy
I have the HE-MAN locker...haha...its bangs and clicks for sure...soft locker is supposed to be nicer though
they don't come apart, its the gears that start howling. Seems they just can't take the abusive m6 launch <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
4th
Full 28" tires (28x11.5x15 Hoosier QTPs)
In the 1.6s, I've been having a few issues with my suspension which I'm addressing now
its ALOT of gear on the street with GSCs
On GSCs they wrap out FAST. on the 28's its not too bad...1-2 shift at 50-60 feet out
I think the 28"/4.71 combo is comprable to a 26"/4.30 gear if that helps you out. but the 28" is taller thus has more sidewall to help cushion the launch.
Old Jun 13, 2002 | 11:40 AM
Ws6Luvr's Avatar
If I was gonna be trapping 122 or so, what gear would you recommend? It would be at it's PEAK power (stock internal) so i couldn't do anything more power related, it would all be setting up gears and suspension to get that magical 10 with stock internals. What would you recommend. The only reason i ask is becuase i have heard of quite a few classes where they are liimited in power so they compensate wiht INSANE gearing and still run SWEET et's. MPH doesn't matter to me, all i want is the ET.
Thanks
Nitin
Old Jun 13, 2002 | 01:32 PM
Fireball's Avatar
for stock internals I'd limit myself to a 4.30-4.56 gear on 27-28" tires or a 4.10 with 26s
Old Jun 13, 2002 | 07:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have the 31 spline Tractech soft locker in my Moser 9".
I have also been in Fireball's car.
My soft locker makes very little noise compared to his.
I have seen 12 bolts die after a number of hard launches on big slicks.
Mine has seen 1.51-1.55's and it's fine.
Old Jun 13, 2002 | 08:22 PM
Gold Phoenix's Avatar
What about using a spool for both street and strip? A Posi doesn't keep power to both wheels very well and a locker would be too noisy for me. So how about a spool? Also on the 9", how hard to get ABS on the center section? My stock ABS sensor is on the differential.
Old Jun 14, 2002 | 06:42 AM
Fireball's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Gold Phoenix:
<strong>Also on the 9", how hard to get ABS on the center section? My stock ABS sensor is on the differential.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">not possible at this time to my knowledge
Old Jun 14, 2002 | 10:07 AM
LS1Tech Co-Founder
If the car is 80% strip I would do a spool.
I'm at this point, but frankly the soft locker is great.
I killed a 31 spline posi.
