Gear Break-in question
Im having gears installed in the 10 bolt along with a complete rebuild. I am familiar with the fact that gears are supposed to be broken in with special procedure. But i also have to make a 2 hour interstate drive later that afternoon (depending on time) or the following day...is that possible or is that going to be bad for the gears?
baby thoes gears and bearings for 500 miles.
He had a shop 2 hrs+ from him install a gearset, and drove it home. The rear end pretty much turned to mush, the gears were ruined. It was a Superior gearset. Whether it was due to the make of the gears, the drive, or the install, I am not really sure...
Technically it does need a couple heat up/cool down sessions. You mentioned driving home the next day...is that possible? Have the shop finish the car, go for a short drive 15-20 minutes to heat up the rear end, then let the car cool completely off. Then on your way home the next day stop after 30 miles or so and have lunch, let it cool off...
The gears are going in Friday (tomorrow), but im not driving home till Sat. Hopefully the shop will finish early friday so i can drive around and make some short trips and cool down sessions before i drive 130 miles the next day...ill see what the guys at the shop say about driving for that long. As far as parts go I ordered Strange Gears, and its a shop that only does custom rears, so i feel confident in their work.
I already put on a lil over 100 miles doing the following procedure including a complete overnight cool down. I decided to drive sunday instead of saturday for good measure, and still plan on taking it pretty slow and stopping often. Hopefully everything will be ok. The guy at the shop said it should be fine as long as I followed the steps for the first 100miles. I have been babying the throttle, but I can still tell that the swap made a big difference. I cant wait till after 500miles and I can get on it a lil more, and realy see.
** side note: went from 2.73 to a 3.42
If you dont mind me asking, how much did that run you?
