Help me select a gear set guys
I'm almost a full bolt-on car right and am looking to do a rear-end swap before I go heads/cam and nitrous. The goal is a 10 second street/strip car.
I've decided on a Strange S60 but I'm sort of confused on what gears to choose that my car won't eventually outgrow. I know 4.10's are good for a bolt-on/cam car. But what about later on when I add 100 maybe 200 shot? I plan on keeping the car a long time, and if I have to rebuild the lower half of the engine, I'm going to probably go with a stroked 383 for even more power and an even bigger shot. Should I just go with 4.10's and compensate with a larger tire in the years to come, or would I maybe be better off starting with some 3.73's, or maybe something different altogether. I don't want to have to keep changing gears for my setup to go down the track as I keep modding in the years to come.
Thanks for any help,
John
John
Yeah, it is an M6, I thought that was in my sig, guess not.
Any other input would be appreciated regarding other peoples setups, gears, 1/4 mile, tach and tire info.
