Gear install= irregular noise from Right rear.
Just had 4:10s put in. They seem to be good. Only problem is, after about 110miles, there is this irregular, nearly dragging sound coming from the right rear wheel. It is releative to RPM, yet it is not constant. Is it common to have an e-brake issue after install? The axle shafts were perfect and the bearings were very good, so I pretty much ruled that out(less than 50k miles). What would be specific to the Passanger side? Any Ideas?
Thanx.
Thanx.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
