spool vs differential
Originally Posted by 6-Speed Terror
im new to this and was wondering if you use a spool you can not use a differential right if so which one is better
I recommend using the Truetrac differential for street use for all but the serious high horsepower cars. If you have 600 rwhp or more, I would go with the spool. I've driven spooled cars quite a bit on the streets, and in the rain you just have to be careful going around corners. Bob
Why not just buy a DETROIT LOCKER? Axles are locked together when under power and let loose when you make a turn. The good thing with a full blown locker is that there are not parts to wear out(stupid *** clutches)like in a limited slip or a posi. Plus if you get it from the right place, if you break it(not likely) then you can send it back and get a brand new one for FREE!
