moser 9 inch axle install help?
I'm putting my moser 9 inch together everything is going good untill I tryed to install the axles. The driver side went in fine then I tryed to do the passenger side it won't go in. It seems like the bearing is to big, so I tryed slidding the driver side axle and it dosent fit either so I know it isnt the axle and bearing. It seems like the hub on the axle housing is a hair off should I try pounding it on? has anyone else have this problem, someone please help
Originally Posted by Wnts2Go10O
sometimes it needs a little persuasion, coat whatevers stopping it with some oil/grease and maybe get a dead blow hammer and tap it in.
thanks guy for your input. I noticed that the rear looks like it got damaged during shipping. the end of the axle tube were the backing plates bolt onto was bent and scuffed which were the bearing slides into had a high spot all we did was grind it down little bit and the axle slid right in with a little help.
