fix for 9 inch hitting floor?
my 9 inch is hitting my bump stops and the bottom of the floor.should i just get a rubber hammer and make some room?
also what to do with the bumpstops?cut them in half for clearance?
Raise the car up till it stops hitting. That is the classic 9 inch hit right there . The next place will be the drive shaft tunnel from the torque arm if it hasn't already. Once you cut the bumpstops it will .
That's exactly where mine is hitting and at the rear passanger seat, but I am not lowered. I did the BFH, but it still bottoms out. I also can hear a clunk right by where the the torque arm can flex back and forth and was wodering what people do to stop this????
