richmond whine
Old Sep 18, 2006 | 11:42 PM
Gearhead125's Avatar
Red face richmond whine
well i just got my richmond 4.10s along with ratech master kit installed the other day
everything was set correctly pinion bearinbg pre-load 24 inch/lbs, backlash .007-.008" , and gear pattern/depth couldn't of been better. But i still get whine not so bad 1-4th gear but on the highway is substantial. Anyone expierience same thing? a
also should i change gear oil after 500 miles, and when you think it would be safe to "beat" on it?
thanks
Old Sep 19, 2006 | 12:23 AM
chicane's Avatar
What weight and type of gear oil are you using ??
Old Sep 19, 2006 | 01:14 AM
royal purple synthetic 75w-90
Old Sep 19, 2006 | 10:23 AM
WS6FASTTOY's Avatar
I heard richmond sucks, you should go GM gears.
Old Sep 19, 2006 | 10:46 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
IMO you have 2 strikes against you. One being 7-8 thousands becklash and the second running a synthetic oil for break in. Richmond gears like backlash to be a little more open say like 9-10 and a dyno base oil.
Good luck.
Old Sep 19, 2006 | 02:51 PM
in the gear install writeup under rear end faq it says richmond calls for .006 , and a good overall BL is around 8-12 , so i comprimised
should i change oil at 500 miles?
Old Sep 19, 2006 | 11:04 PM
chicane's Avatar
I gotta second Scott on this.
FYI: The FAQ is just a guide line. I have done gear sets that called for a specific lash, but in the housing they were going into... it turned out quite different all together. The old rule of thumb is 0.001" for every inch of ring gear diameter.... but even that is a guide line to get you close.
I would step up to a straight weight 140 oil as well, when you get to an oil change in the differential.
Old Sep 19, 2006 | 11:45 PM
any particular brand, synthetic, is it alright to use for everyday use? the thicker oil should reduce the whine right?
thx for the help btw
Old Sep 20, 2006 | 12:10 AM
well i just read some of your other posts, where can i get Schaffer or Torco 140? Should i add friction additive if its a torsen? with the thicker oil what should BL be opened up to, to allow for proper lubrication
Old Sep 20, 2006 | 12:15 AM
chicane's Avatar
PM sent....
Old Sep 20, 2006 | 02:52 AM
DaGeneral's Avatar
oh man. I thought I was alone.
The whine from my Richmond is annoying !! Especially on the freeway.
Accelarating from 1-4 not so much, but once on the freeway it irritates me. I used the GM Differential Fluid and an additive they gave me.
Im thinking about stepping up to the 140 oil.
Old Sep 20, 2006 | 05:44 AM
samdogmx's Avatar
my richmonds are quiet, I like the others have said I run more like .008-.010 backlash
Old Sep 20, 2006 | 08:18 AM
onebad82z's Avatar
I am happy thus far with my first set of Richmonds (3.73) in my 12 bolt.I set it up with the backlash at .010".It was loud upon the initial 10 mile break in,but after 4 more of those cycles it quieted down nicely.By the end of last summer I had around 300 miles on the rear and it had become nice and quiet.I get a slight howl around 45mph but nothing I can't live with.I emailed setup pics to Richmond and Randys ring and pinion (where I bought the Eaton) and they said that it looked the best I was gonna get them since they are Richmonds.This is my third rear to date I have built myself and am happy that I got it as well as I did.
I plan to service it with the Schaffer #209A 140wt oil since I need to get the synthetic out of it.I ran it since it came with the gears and install kit but after researching it realized that was rather dumb.The car has sat all summer since I am about to finish up my T56 swap,I just hope the synthetic didn't eat me Eaton up since it has been sitting
Old Sep 20, 2006 | 11:48 PM
when i change the gear oil over to the shaffer im gonna re-check the BL and open it up to ~10, i knew 6-7 was too low, should of went with my instincts. hopefully i can still save the gears
