abs
Old Sep 22, 2006 | 01:43 AM
SLP4CamaroSS's Avatar
Default abs
are the abs units different in the 3channel and 4 channel? can u just splice some wires to make the 3channel connect to the axels senor ports on the 4channel rear?
Old Sep 22, 2006 | 08:57 AM
Chris 96 WS6's Avatar
No, they are different. I suppose, however, that you could make the 3 channel ABS unit read off one of the axes rather than the ring gear. The issue would be the number of teeth the ABS module is expecting to see. You'd have to change out the reluctor ring on your axle to get it to read right.
Old Sep 22, 2006 | 12:57 PM
can u use a 4 channel modeulator and put it on a 3 chann car
Old Sep 23, 2006 | 04:21 PM
ttt any one know
