how much to replace axle bearings, wheel bearings?
I think the noise i have is that, only happens once the car is a bit warmed up and on slow takeoffs and coming to a stop with the rotation of the wheel though. I just want to know the ballpark for labor?
Mike
Mike
It sounds ridiculous, but if it is a low frequency noise (not a squeak but more of a whomp whomp whomp sound), check your tires for staggering and/or rotate them to troubleshoot it first.
Staggered tire wear causes this type of noise.
By staggered wear I mean the top rear of one tread block is higher than the front of the next one. Happens to the front tires when your alignment is a little off. Cars that are technically in spec for alignment can do this, and it can happen very quickly (just a couple thousand miles) on cars that are off.
LS1Tech Sponsor
Originally Posted by Tirefire
Hey Scott, quick question can my axles actually lock up cause of this??
No, the axle bearings will cut into the axles and then the flange could break off. I have only seen this one time in a Mid 80's Dodge Ramcharger towing another truck on an open trailer with low oil in the rear axle.
are the bearings wear items, i changed my fluid around 12k miles ago. Its only from taking off from a stop at sub 10mph speeds then you can't hear it anymore. Also when slowly slowing down it will do it. Like if i take off on hill and roll, it makes the sound with the rotation of the tire.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
i got another question i dont no if is my wheel bearing or something else but it clicks when im turning left it only doest it sometimes. How would i no if its the wheel bearing is there someway to check it
