Moser 12 bolt leaking question
Old Sep 23, 2006 | 07:09 AM
NJgunslinger's Avatar
Default Moser 12 bolt leaking question
I have just had a 12 Bolt Moser installed on my 2000 Ta. It seems like it is leaking from the front seal of the 12 bolt rear. oil on the exhaust in that area. Has anyone else experienced this problem. Ths shop that installed the rear says that the Moser rear is known to leak from there. Anyone else have this problem?
Thanks
Old Sep 23, 2006 | 11:31 AM
EPP's Avatar
EPP
No, it is not normal. Give whoever you purchased the rear have Moser send out a new seal. Bob
Old Sep 23, 2006 | 11:36 AM
EPP's Avatar
EPP
No, it is not normal. Give whoever you purchased the rear have Moser send out a new pinion seal. Bob
Old Sep 23, 2006 | 11:41 AM
thanks. they are checking out.
Old Sep 24, 2006 | 08:44 PM
lowws6's Avatar
I had the same problem with mine and it turned out to be a small hole in the case. I called Moser to get a new seal and they told me to check for porosity in the case. I found the hole and had to send the rear back to them.
here is the pic
Old Sep 29, 2006 | 09:42 AM
UMD_Jesse's Avatar
From: Fairfax County, VA (You know you're here when you see the bad roads)
How the f- do you get a hole in your rear end housing?!?!? Did it ship like that from moser???
Old Sep 30, 2006 | 01:29 AM
lowws6's Avatar
Yes it was shipped that way. I installed it then came back the next day and saw that it was leaking. I had to take it back out and return it.
Old Sep 30, 2006 | 02:03 AM
94z28L's Avatar
sounds like what scott from DLS was talking about with the problems on the S60 and 12bolt housings having impurities and problems in the castings
