strange clunk
Old Sep 25, 2006 | 05:23 PM
Lythropus's Avatar
Default strange clunk
I searched and only found general clunks that didn't really fit my problem.
My rear end gives a clunk under full throttle, and going around a right hand turn. If I baby it, I get nothing. It also seems to only come from the passenger side. I can drive it as hard as I want...to the left. I was thinking it was the limited slip???
Any suggestions?
Old Sep 25, 2006 | 05:31 PM
blk99camaro's Avatar
having the same problem....listening in....
Jon
Old Sep 26, 2006 | 07:55 PM
ls1lover346's Avatar
cmon ppl i got this prob too, wats an answer, but more i have a clunk under light acceleration
Old Sep 26, 2006 | 11:24 PM
Lythropus's Avatar
I assuming it'll get worse so I'm still babying it, HELP SOMEONE!
Old Sep 26, 2006 | 11:40 PM
2001stripper's Avatar
Jon
Me too. Mine makes a clunking sound when I cut the wheel right or left....on the highway....no sounds. Just got back from the track....I think that my 10-bolt finally went bye-bye....not bad after 300+ passes. On a bright side, I ran a personal best of 12.65 @ 114.49 on street radials. Time for a 12-bolt with 4.10s
Old Sep 27, 2006 | 07:02 AM
anyone??
Old Sep 27, 2006 | 03:23 PM
camaronut502's Avatar
Mine does the same, I had some one watch me do my burnout and one tire would spin, turning in the pits i would here a clunking sound. some local guys are saying it may be the spider gears.
Old Sep 27, 2006 | 03:47 PM
dailydriver's Avatar
Originally Posted by 2001stripper
anyone??
Did all of you already check your LCA & PHB bushings/bolts for wear or being loose??
BTW 2001; I thought I had the most lightweight/no option/stripper, daily street driven car on here. You've got me beat, as I still have a stock stereo system!! Isn't it GREAT NOT having all of those power; window/seat/mirror problems everyone else seems to have to suffer through (as well as the lighter weight)??
Old Sep 27, 2006 | 09:10 PM
Turns out, I sheered some teeth off my spider gears. Dealer wants $1300 to fix it. I think that I'll throw in a 12-bolt w/ 4.10's and spend the extra $1000 and get something that is going to last.
Hey, dailydriver, I have the factory radio also but that is about it for options. Did you ever get yours weighed? What times are you running? Good to see another fellow stripper out there!
Old Sep 28, 2006 | 01:33 PM
Lythropus's Avatar
Spider gears are the gears inside the differential unit? Can't you buy spider gear kits to rebuilt the stock diff?
Old Sep 28, 2006 | 07:25 PM
I've never been able to get an accurate weight, but at E Town's VERY unreliable scales it came in at about 3360# with a half tank of fuel, without me in it, and sans jack & spare.
My best is a 12.67 @ 112.64 on a 1.90 60' (8.23 @ 85.77 1/8th)
This was with; lid, filter, SLP CAI, 4.10s, Nitto DRs, Random Tech torque arm, SLP y pipe, 2OTL catback, Pro 5.0 shifter, Mac cover, 1/4 tank of 93, no jack or spare, or mats, and a 60' destroying road race/handling suspension setup (full size fronts, swaybars, GC coilovers with Koni adjustable shocks (NOT their drag shocks!). EVERTHING else was pure stock (intake, exhaust manifolds, cats, internals,etc.).
