handle it?
Old Sep 27, 2006 | 11:12 PM
da boss's Avatar
Default handle it?
I was just wondering if my stock rear would hold up with these mods.
2001 Trans am M6
Current mods: full exhaust, slp lid, k&n,
Upcoming mods: 4.10 gears, nitto 555r's, Trex cam, 150 shot, electric water pump, subframe connectors, electric cutouts, and dyno tuned. I plan on finishing up these mod by the end of the year and would like to see if maybe i should forget the cams and save up for a rear end? Thanks for any help
Old Sep 27, 2006 | 11:30 PM
Studytime's Avatar
NO!
It will not hold up. I'd save for the rear if you can't afford to have your car down between 10-bolt repairs.
Good luck.
Ben T.
Old Sep 28, 2006 | 01:38 AM
hpjunky98's Avatar
and i would save your money on the cam"s"... you should really buy only one...
Old Sep 28, 2006 | 05:16 AM
EPP's Avatar
EPP
I normally have a pile of 10 bolts out back. I have seen the lowly 10 bolt break on bone stock cars. The six speed cars are the hardest on them. Bob
Old Sep 28, 2006 | 11:18 AM
black01_WS6's Avatar
Yup what Bob said. I broke mine when I was stock, for about a month or so. Good thing I live 10 min away from EPP at the time.
Old Sep 28, 2006 | 12:12 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
do it right the first time and get a 9" or nice 12 bolt... my truck has gone through 3 10 bolts already... next time this one breaks the 14 bolt SF will be going in...
Old Sep 28, 2006 | 04:21 PM
Ouija's Avatar
Originally Posted by Studytime
NO!
Best response ever!
No way in hell that will hold up to a 6k clutch dump on the sauce. Probably wouldn't even make it through one launch...
Now if you are easing into the clutch @ 300rpm not spraying in first, nor spraying between gears, sure it will hold up, but if you are doing that, why the hell are you at the track?!!?
