What would you do?
Old Sep 29, 2006 | 10:06 PM
2002camaross35th's Avatar
Default What would you do?
Hey guys iam a little confused on what i should do next. I have a 2002 Camaro SS M6 it is not a daily driver just a weekend warrior..so far it has air lid, qtp headers, ORY, QTEC, T-Rex with all vavletrain work, 4.10's in the 10 bolt, 275/40/17 m/t drag radials. Since iam going to be going to the track more often i was thinking about getting a moser 12 bolt 33 spline w/posi and abs with 4.56's i was planning to run a 28' tire also at the track to match my gearing. But then i was also thinking of gettting a good set of flowing heads sumthing like 225 afr or trickflows. Im a little confused on what i should spend my money on because i know i cant have both at the same time yet so my question to yall is what would yall suggest if yall had around 4G to spend
Old Sep 30, 2006 | 01:06 PM
CW00BlackTA's Avatar
I'd buy a Ford 9 inch set up the way you want it. Why? Because your 10 bolt isn't going to last on sticky tires at the track--even less so if you did the heads first. I recommended the 9 inch because you are an M6 car and planning to add even more power. The 9's are stronger, have more differential options and are easier to work on.
