Help with Moser 12-bolt install
Old Oct 12, 2006 | 05:03 PM
WhynotSS's Avatar
Default Help with Moser 12-bolt install
Just blew up my 10-bolt and picked up a Moser-12 bolt with true-trac, and 33 spline axles. I dropped the axles off at a rear end shop to press on the bearings and they do not know what the caliper bracket is. I guess the caliper brackets from the stock axles are permanently attached to axles. Does anybody know what's wrong? If I need to order another piece from Moser, what is it?
Old Oct 12, 2006 | 05:14 PM
indirocz28's Avatar
cut stock off w/ torch, replace on new rear
pictures would help if you had any.. thanks
Old Oct 12, 2006 | 06:48 PM
BerryWS6's Avatar
Are you talking about the brake backing plates?
Old Oct 12, 2006 | 07:51 PM
WhynotSS's Avatar
It's the caliper mount. Moser has a diagram of how to install the bearings onto the axles. The caliper mount goes on before the bearings are pressed on.
