Click Click with my moser 12 bolt
At low speeds and while taking some corners my Moser 12 Bolt makes a clicking noise. It very noticable and loud if I am taking a very slow sharp corner. I have heard that the sway bar may be the culprit and the sway bar is almost rubbing the rear end cover when I slide under the car to take a look. I have a stock rear sway bar with poly bushings/mounts. The first thing I was wondering is what can I do to give the sway bar/rear cover a bit more breathing room? Second what else could the clicking be? Third what oil/lube is recommended for a moser 12 bolt with eaton posi? Thanks.
